2004-04-01
09:30 AM
2023-05-26
03:27 PM
Rubia Torres
2004-04-01 12:28 PM
2004-04-01 05:36 PM
Petros wrote:Thanks, Petros. The explanations are quite detailed--until you get to the last one: "6. It is also possible that what happened is unimportant, as it has no real effect on the operation of ArchiCAD."
there is a topic in archiguide
http://www.graphisoft.com/support/archicad/archiguide/Errorsduringlastop.html
2004-04-01 06:33 PM
2004-04-02 08:34 AM
2004-04-05 05:59 PM
Petros wrote:I merged the project following Eric Batte's method at http://archicad-talk.graphisoft.com/viewtopic.php?t=973 . Unfortunately, it didn't help. The problems are in several of the 8.1 library casement windows. I'd rather not have to delete and re-create all the windows (obviously). Any other ideas?
Did you try to merge your project into a "new&reset" pln? Sometimes it solves those mysterious uknown problems
2004-04-05 07:08 PM
2004-04-05 07:44 PM
Geoff wrote:Geoff,
Try turning on the preference to write a report.
2004-04-05 09:15 PM
2004-04-06 07:30 AM
Link wrote:For those following this saga, I sent Link the pla and he found no problems with the file. So our guess is a corruption in AC somewhere. I'm going to reinstall AC--a pain since the latest CD needs the "+" update. If I trash my AC folder, and install a fresh version, will the install overwrite all the files not in the AC app folder (since I'll be installing an older version)?
Can you upload or email a PLA of this project?
