railing
I use library to make railing for my project. The problem is the railing from the library cannot adjust the long. I also try to strage, but it doesn't work. How to make a workable railing?
11 REPLIES 11
Thank you! that solve some of my problem.
I also need to make railing for curve balcony as the picture that I attach. Is there anyway that I can make my own railing? Is it hard to make our own railing?
Djordje
If the standard curved railing fits design wise, the "only" thing you have to do is to set the parameters right.
If not, you can build your railing out of curved walls and slabs and objects, save it as object or a module if it is to be redefined/refined later.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
