So the Revolution Axis must be in the X-Y plane.
This is true for the Detailed Geomety Method.
If you create a Revolved Shell using the Simple Geometry Method, the Revolution Axis will be vertical, but the Profile will be a quadrant.
So in your case you need to create it in the Floor Plan View and then select it, go to 3D and use the 3D Free Rotate command of the Pet Palette to rotate it to the correct position.
Or you can just go to 3D and do it there. You can first define the Editing Plane (should define a vertical plane or click a vertical surface of an existing element), then draw the PRofile and the Revolution AXis in the Editing Plane.
