2008-03-19
09:20 PM
2023-05-23
03:12 PM
Rubia Torres
2008-03-20 04:24 PM
2008-03-20 05:14 PM
2008-03-20 06:53 PM
Peter wrote:If you're using the roof to make fascias, you are pretty much causing your own problem. It's made for roofs, not for making a big blank fascia a weird thickness of roof.
The problem for me is if you are using the roof tool for a different purpose than designed. You might prefer the roofsverticalthickness to stay the same regardless of the angle. At the moment you have to keep changing the vertical thickness after you have adjusted the pitch to keep it correct. I know it's not a massive problem for most people but I think the option should be there.
2008-03-20 07:16 PM
TomWaltz wrote:So using a slab as a "flat" roof or as a counter is a no-no since the Slab Tool is for Slabs?Peter wrote:If you're using the roof to make fascias, you are pretty much causing your own problem. It's made for roofs, not for making a big blank fascia a weird thickness of roof.
2008-03-20 07:57 PM
TomWaltz wrote:Yes I know I tend to be the main cause of my problems! It's the story of my life
2008-03-20 10:05 PM
Peter wrote:So that you
OK, A question - Why have the option in the settings dialog box to adjust the vertical dimension in the first place, if we are not allowed to use it and doesn't remain set if you change the pitch?
2008-03-20 10:13 PM
Peter wrote:Too late!
At least two people can see the possible use for this. We aren't that crazy are we? Don't answer that!
2008-03-20 10:23 PM
Laura wrote:I don't want to do it manually though, I want the computer to do it for me!
So that youcan-- as it appears youwant to do...
TomWaltz wrote:Thanks Tom!
Too late!
2008-03-21 09:54 AM
2008-03-21 10:46 AM
Peter wrote:I often use roofs, and roofs upon roofs, to model real roof structures. I still can't see the use for this (locking "vertical thickness")- when I dimension the structures, I always give the parts' thicknesses (perpendicular to their length), not some arbitrary inclined measurement depending on the roof slope. So I find Archicad's behavior in this case quite to the point.
The logical solution would be to have way of 'locking' either of the thicknesses, when using a non-composite, so as to indicate which was the important one for the roof.
