Shae and I talked offline.
There is a major bug in the 12 library that prevents Roof Maker from doing the right thing. Even a simple shed roof gets the wrong rafters (short hip rafters THiprafter2_1 12) among other things with the 12 library. With the 11 library, it's fine, using Rafter2_1 11 with the correct length, etc.
Clearly GS has a GUID problem between the add-on (I'm using the Roof Wizard) and the 12 library. I'll report it.
Shae worked around his problem by generating his structural elements with RoofMaker in 11 and pasting them into 12.
An easier workaround is this:
Temporarily remove the 12 library from Lib Manager and load the 11 library instead. Ignore all of the error messages.
Run RoofMaker (wizard or whatever).
Open Lib Mgr again and remove the 11 lib and put the 12 library back.
Glad for Shae that it's Friday...
AC 28 USA and earlier • macOS Sequoia 15.3, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
