ā2004-11-20
08:59 PM
ā2023-05-23
03:39 PM
Rubia Torres
ā2004-11-21 06:14 PM
bell63 wrote:The problem is the angles that ArchiCAD cuts on the four sides of the hole for the skylight (rooflight). This is a long standing complaint. If the skylight tool cut perpendicular sides for all four sides, and then had the user adjust the angles to their needs, there would be no problem at all.
hi!
when trying to place a roolight in a roof with only 1.5 degree fall, I get an error message something like --'roofs below 20 and above 40 degrees need special solutions'.
What's the special solution then?
How do I place the rooflight without the roof getting all 'messed-up'?
many thanks
jonathan
ā2004-11-21 08:43 PM
ā2004-11-22 02:57 AM
So, here's the "special solution" (workaround):I "believe" you can simply place the skylight without changing the pitch, and make perpendicular just the angle on the upper side of the roof hole.
Change the pitch of your roof to be steeper than you intend so that you can insert the skylights without the error.
Now, select the roof (only). If you are 9.0, it does not matter what tool is selected. In earlier versions, select the roof tool. With the mercedes cursor on any skylight hole edge (if you are changing all), or on the top or bottom edge (if you are only changing those two), select the edge angle button in the pet palette as shown in the attached screenshot. Make the edge (or all edges) perpendicular.
Finally, change the pitch of the roof to the pitch that you originally wanted.
ā2004-11-22 05:09 AM
Link wrote:You're right, Link! You can just put up with the error message and then change the upper edges of each skylight.So, here's the "special solution" (workaround):I "believe" you can simply place the skylight without changing the pitch, and make perpendicular just the angle on the upper side of the roof hole.
Finally, change the pitch of the roof to the pitch that you originally wanted.![]()
ā2004-11-22 07:41 PM
Karl wrote:Mhm ... quite fast when you have 120 of themLink wrote:So, here's the "special solution" (workaround):You're right, Link! You can just put up with the error message and then change the upper edges of each skylight.
Change the pitch of your roof to be steeper than you intend so that you can insert the skylights without the error. ///Finally, change the pitch of the roof to the pitch that you originally wanted.š
ā2004-11-23 01:54 AM
Djordje wrote:Yikes!!
Mhm ... quite fast when you have 120 of themš
NOT!
ā2005-11-02 01:40 PM
ā2005-11-03 06:09 AM
Tom wrote:Is your flat roof done with the ArchiCAD roof tool, or as a slab?
I'm trying to place a skylight object (Skylight Pyramid) in a flat roof, and I keep getting an error message about the skylight being outside the roof area. The skylight is placed, but it doesn't cut a hole in the roof, and isn't linked to it.
ā2005-11-03 10:50 AM
