simple modling
How do you create simple base boards and trim and molding for floors and wall/cieling intersections? I thought that would be a simple tool like the wall tool or soomething. Thanks.
Morphious
2 Replies 2
Dwight
Welcome to the forum.
In order to serve you better, forum members need to know your Archicad version and a little bit about your computer system.
Please add this information to your signature.
Depending on your Archicad version, the tools are:
"Wall Accessories"
Download from Graphisoft web site by using the "Goodies" link in "Help"
AND/OR
"Complex Profile" - for custom wall accessories extruded as if they were wall parts.
Both are well-covered in the reference material, but require some lateral thinking to apply well. See what you think.
Dwight Atkinson
"Wall Accessories"
AND/OR
Then there's also the very old little, tiny walls (and/or beams, columns, etc.) method (with or without profiles) that is a bit more tedious but also more versatile and so may still be required in some cases.
...and there are still some cases where only a library part will do (ornate modillions, metopes, triglyphs, dentils and such).
