‎2008-02-06 06:36 AM
‎2008-02-06 11:08 AM
‎2008-02-06 01:02 PM
‎2008-02-07 01:39 AM
TurboGlider wrote:Yes, that is also possible. But you would have to re-do it every time anything changes in the buildings (that you want to reflect on the site plan).
You could also save as GDL in 3d view with the layers that you want to show on siteplan. Then you put this GDL object in your site.pln file. If you have to make som adjustment after you have place it on site, then explode the object and you will have only 2d pieces left that you could edit.
