sketch render sections and elevations???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2006-11-08 02:49 PM
As far as I can see there's no way of putting Sections/Elevations through the sketch render engine. You can put a camera in and change it to parallel projection, yes, but it loses the scale !!!
Any suggestions?
Adri
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-11-08 07:38 PM
If you want a similar look from a S/E, save it as a pdf and open it in Photoshop and apply the appropriate filters. This will allow you to keep scale as long as you preserve the image's dimensions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-11-08 08:20 PM
Geez. Put an element of known length into the view and stretch the rendering back to scale using it as a guide.
There is also a product called "ArchiSketchy"
http://www.archisketchy.com/
Crude solution:
You can take the section, convert it to a drawing, and substitute the straight linework with a squiggle line.
You'd make a squiggle line with some short line segments arranged irregularly and save it as a line type.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-11-08 09:04 PM
Dwight wrote:But teacher, that could be 3/16 of a millimeter off!!
1: Sketch Rendering loses the scale?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-11-08 09:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-11-08 09:34 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-11-08 09:39 PM
3/16mm = seven thou.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-11-08 09:46 PM
Thomas wrote:Yeah, but I've got sarcasm down!TomWaltz wrote:
3/16 of a millimeterTom, I think you've misunderstood the benefits of the metric system!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-11-08 09:54 PM
Like Whitworth spanners.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-11-08 10:56 PM
Dwight was on the money, as usual, but, if you place a marquee oriented with your desired section,
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
