License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
snaps don't appear to work
ngoldie
I am trying to draw walls over a trace reference and no snaps seems to be working, is there somewhere to turn them on?
Thanks
Naomi
Archicad 20
MacBook Pro - laptop
5 REPLIES 5
If you switch over to the trace reference can you snap to it then?
I am just wondering if it might be a PDF or something that doesn't have points that you can snap to.
ngoldie
Hi Barry,
Yes it's a pdf, I didn't realise you couldn't snap to pdf's drawing points.
Thanks!
Naomi
Archicad 20
Erwin Edel
You can explode a PDF in to lines/fills, but in my experience the measurements aren't very exact (lots of decimals or just plain off by more than half a mm).
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
It depends on the PDF.
If it was produced from a vectorial program like Archicad then if you can't snap to the points directly you may be able to 'explode' the PDF and convert it to lines.
I know Archicad PDFs can now have layers but can't remember if the points are snap-able or not or if you always have to explode the PDF first.
If it is a scan from a photocopier then you can't even explode it as it is just a bitmap image.
Erwin Edel
Might just be my bad luck with vectorial PDF then, or exceptionally sloppy drafting on the end of the party responsible for those PDF drawings.
www.leloup.nl
Windows 10 Pro
