spider glass on curtain wall
heya,
im trying to create a curtain wall with just glass pannels and spider fixing, but am having trouble in doing so.
i couldnt find any other posts with an explination on how to do it so i thought i would post.
thanks for your help
something like the attached image
7 REPLIES 7
i have managed to get just the glass but i can seem to set the spider junctions
rocorona
Did you try the JOINTS section, in the Courtain Wall settings?
On mine they are there.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
i cant seem to find the joints section. is it subbed under another heading?
i have scheme, frames + subs, panels + subs, junctions and accesories, im runnin ac12 so i should have it
ahha no worries worked it out.
i have an error message saying 'File not found at line 21/ 44 in th 3d script of file cw panel 12.gsm.'
and it wouldnt display it - anyone know what this means (it only happens with the curtain wall
anyone had this problem?
Erich
I don't have AC available right now to check. However, if it says "file not found" it sounds as though the part is calling for a macro that is not in a loaded library. Check to make sure all necessary libraries are loaded (could this be a custom part for the curtain wall?).
Other than that you will need either someone more versed with this part or at least someone that has AC available to look at the part.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
David Maudlin
dtorretto wrote:
i have an error message saying 'File not found at line 21/ 44 in th 3d script of file cw panel 12.gsm.' and it wouldnt display it - anyone know what this means (it only happens with the curtain wall
dtorretto:
Are you sure the message is not Fill not found at line 21/ 44 in th 3d script of file cw panel 12.gsm.? Lines 21 & 44 are:
sect_fill internalFill_1, internalFillPenBg_1, internalFillPen_1, gs_cont_pen
so check under the panel settings Panel Type and Geometry > Cut/Outline Attributes > Internal Fill to see if the fill is "Missing". (This same problem occurs for doors).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
