dtorretto wrote:
i have an error message saying 'File not found at line 21/ 44 in th 3d script of file cw panel 12.gsm.' and it wouldnt display it - anyone know what this means (it only happens with the curtain wall
dtorretto:
Are you sure the message is not
Fill not found at line 21/ 44 in th 3d script of file cw panel 12.gsm.? Lines 21 & 44 are:
sect_fill internalFill_1, internalFillPenBg_1, internalFillPen_1, gs_cont_pen
so check under the panel settings Panel Type and Geometry > Cut/Outline Attributes > Internal Fill to see if the fill is "Missing". (This same problem occurs for doors).
David
