stairmaker ac9
I am looking for an alternative to stairmaker. I need to model many different stairs and railings (mostly existing), and have grown tired of STMK limitations. I also would like to have a stair in my plans that actually demonstrate I have handrails and handrail extensions on my stairs.
I have read a little about smartparts and archistair, and have no idea how these compare, some in-use information would be very helpful.
Thanks
Christopher Sipes, R.A.
PMG5 2.0 Ghz dual, 2.5 GHz RAM, 160 GB, AC 9.0
6 REPLIES 6
Djordje
ArchiStair by Cigraph. Go to http://www.cigraph-store.com/html/home/CIG-INDEX.htm
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje, is this what you use? If so, that is enough of an endorsement for me....
Are there any other "must have" add-ons?
Thanks a ton
Christopher Sipes
MacOS 10.4.1, PMG5, 2.0 Ghz dual, 2.5 MB RAM AC9.0
maybe not must-haves, but depending on what you're doing, pretty much anything from cigraph can be very useful. Their site & massing programme saves me loads of time doing site surveys, for instance.
cheers,
dan
Stephen Dolbee
Door/Window Builder by Cadimage.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Achille Pavlidis
i'm actually using Stairmaker and its pretty good... although it lacks one feature i think it is important... the possibility to have more than on landing... you can always ad one with a slab but the railing is discontinued...
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
TomWaltz
Steve
I used to believe that.... until I learned how to make completely custom doors/windows on the fly using the "custom panel" and "custom grid" options on most objects.
Granted, there are some limitations to that method, but I found Door / Window Builder to be pretty cumbersome, bioth in the sense of using it and in the sense of performance. I found the D/W objects really slowed down elevation regeneration time compared to the GS and SmartPart windows.
Tom Waltz
