storeys views
Llian
here is the picture of the basement floor plan. the trace is on and it shows the stairs from above down to this basement. why is the stairs not showing ? I have checked my section and it the stairs is correctly located from above leading to basement.
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
5 REPLIES 5
Have you set the properties of the stair object to "Show on home storey and one storey below"?
Llian
here the section showing the stairs going down to basement. the basement plan is not showing. i also attached the floor cut plane. any help???
Lilian Seow
Llian
my floor cut plane settings.....
Lilian Seow
Llian
i have set to all levels but it's not showing the riser and treads??
Lilian Seow
Try selecting the object and looking for a setting called '2d detail level'. Set this to 'scale sensitive'.
Also check the ' 2d above home storey' settings are all checked.
