structural grid tool
I have placed a structural grid on my drawing using the structural grid tool, is there anyway to show the structural gridlines in the elevation views? or do i need to draw them myself?
Thanks
11 Replies 11
this is available in the grid element settings window, although i think some of the options are turned off in the work environment settings, as we were missing most options initially.
see screenshot to give you an idea of what is available; note; section/elevation settings options.
vistasp
Mentor
Cadaron, the AC10 structural grid seems to have a lot less options than in AC12.
Rohan, with default settings, my sections/elevations automatically show the grid. In fact, I'd like to know if it's possible to turn them off! Other than by layers, that is.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
sorry about that, did not spot your profile reference to Archicad 10.
Perhaps it is time to upgrade
and how do u Create a Curved Grid Element ????
David Maudlin
how and what u do to see that menu, i cant see that menu.... What i have to press to see your screenshot, plz
Necko:
Work Environment > Command Layout Schemes > Menus > Grid System ... (Grid Tool)
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Necko:
thx man, i find it finaly, i was reading manual and i read that its possible to draw Curved Grid Element and i just cant do that. I dont need it now but i want to know how
Do u know that ???
In the Grid Element Settings Dialog you define how the Grid Element should look in Section/Elevations, but it is the Grid Tool panel of each Section/Elevation Settings Dialog where you have to enable Grid Elements to be shown in that Section/Elevation.
Do u know that ???
At the top of the Grid System Settings Dialog you find the big button with which you can switch to Radial Grid System.
the grid line created can not be modified in easy way.........
it seems to tell me that i have to draw again
