surface painter
Hello, does anybody know how to assign other surfaces to pointed areas. All is one slab.
You can either put a new thin slab on top of the main slab (you can use the magic wand inside the room), or split the main slab into different pieces. (By using "split" command.)
Richard
AC26 (since AC6.0), Win10
Thanks for answer
