Tom Krowka
tEAMWORK QUESTIONS
How do you redefine views whle in Teamwork. Seems like it can't be done unless you are in a .pln drawing. Is that the case?
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
5 Replies 5
TomWaltz
Views can only be edited/redefined by the Team Work "member" who created them originally.
Tom Waltz
Tom Krowka
Views were created by me when it was a .pln drawing, then I made it a team work project. Who created it now? Nobody?
[email protected]
www.walshkrowka.com
Once changed to a teamworked file the views will now be owned by the teamleader. I would recommend assigning one person to always be the Teamleader and responsible for creating and modifying the viewset.
Tom Krowka
OK I signed in as teamleader, went through all the dialogue boxes, and appeared to sign in fine. However, still cannot access layer combos, individual layers, etc. It seems I am still signed in as a team member, not leader.
When I sign in as team leader, I also sign in as the team member name. Not using a password there, are none are assigned by the administr.
Any help?
[email protected]
www.walshkrowka.com
Tom Krowka
Never mind. Have to sign in with exclusive access. It helps to dig out the manual.......................
[email protected]
www.walshkrowka.com
