‎2008-06-05 08:44 PM
‎2008-06-06 02:08 PM
dmn wrote:Exactly how are you doing it? Write down all the steps of saving the template and using it with a new file.
Okay, this is wierd. When I open the template from a fresh archiCAD session, the layouts show up, but when I try to start a new file from an existing session, the layouts and the masters are all dropped?
‎2008-06-10 08:07 PM
dmn wrote:Yes.
Is it possible to have a set of layouts premade in a *.tpl file?
‎2008-06-10 10:31 PM
laszlonagy wrote:I have the same issue. When you start a "new instance" of archiCAD, it starts a new project file based on the default graphisoft template, regardless of what template you choose. It's annoying, but not a big deal. In the 2nd instance I can then create a new project file using whatever template I want.dmn wrote:Exactly how are you doing it? Write down all the steps of saving the template and using it with a new file.
‎2008-06-11 01:05 PM
