2011-03-10 09:30 PM
2012-11-17 02:37 AM
2013-01-08 12:17 PM
2013-01-08 05:05 PM
2020-11-23 02:43 PM
2020-11-30 10:43 AM
2020-11-30 12:20 PM
 2020-11-30 02:20 PM
runxel wrote:Definitely, I'm not saying one is better than the other. I'm just saying that Archicad is not easy peasy, smooth sailing all the way. Because that's often how it's portrayed online when someone asks for a comparison. Nicer UI and clearer parameters help, but it sure could learn a couple of things from that "other software". Other way around also.
But every software has it's quirks.
2020-11-30 03:46 PM
2020-11-30 07:23 PM
Prvoime wrote:I wish that the shortcuts were taught more explicitly up front, because until you learn those, Archicad seems ponderously slow. For example, I like "Delete" as the final click to finish dimensions. I have the mouse wheel set to left-click as Delete. So, a dimension is click-click-left mouse wheel.
Want to dimension something? Click one, click two... Now what? Right click? No. Enter? No. Esc? NO! Double click on empty space!
You want a wall to be 200cm away from another wall? It's simple, just click on the wall, then Ctrl+D, then click on the very edge of the wall, then drag it over to the other wall, than carefully take your hand of the mouse because if you move it accidentally everything falls apart, than just type D X 200+. Simple! I couldn't believe when I read this, it's like those old AutoCAD versions, with blue screen and no GUI, where you typed in everything.
2020-12-01 06:18 AM
