‎2007-11-09
09:21 PM
‎2023-05-25
05:11 PM
Rubia Torres
‎2007-11-09 10:01 PM
‎2007-11-09 10:54 PM
‎2007-11-09 11:18 PM
‎2007-11-09 11:35 PM
‎2007-11-09 11:45 PM
‎2007-11-10 12:08 PM
‎2007-11-10 07:41 PM
‎2007-11-11 01:09 PM
bertoldi wrote:I have TWO layers for contours: "Contours (Existing)" & "Contours (Revised)." I COPY the existing mesh to the revised layer so the original is never modified from the original survey. On the revised mesh I use the landscape consultants DWG file underlay, or eyeball it yourself and reshape the contours around the house where fill is required. THEN and only then do I create a house pad contour on the mesh. You don't want this shape to cross existing contours. In some cases the front of a building will use this method, but I do not reshape in the back. I will use SEO there for instance. So you can use both methods together.
I have an topography mesh already created, and need to edit it to allow the footprint of my building. What is the best and easiest way to do this?
‎2007-11-11 04:36 PM
Peter wrote:Actually, it's easier than that. In my cold country, the preferred foundation method nowadays is to cast a concrete slab on a layer(s) of insulation, usually 100-300mm EPS (extruded polystyrene) plastic foam sheets. (This gives an optimum of combined heat and moisture insulation for our climate).
..Is it your method to, instead of grouping the floor slab and the basement walls or frost walls and using this group as operator, you would make a special slab on a normally hidden layer as the operator so that you could change the walls, add walls, etc, then edit the
shape of the special operator slab? ...
