Averrell
true line weight archicad, angle shape
Salut!!
premièrement je voudrais m'excuser pour mon anglais je suis français 😅
dans un deuxième temps, j'aimerais savoir s'il existe un moyen d'avoir un "angle pointu" comme Illustrator lorsque j'utilise une épaisseur de ligne réelle? j'ajoute une capture pour expliquer ce que je veux:
Translation...
Hi!!
first I would like to apologize for my english I am french 😅
Secondly, I would like to know if there is a way to have a "sharp angle" like Illustrator when I use real lineweight? I add a capture to explain what I want:
Please post in English only to this forum.
Normally this post would be removed, but as it has been replied to already I have translated it.
Please use Google Translate (or similar) so you can post in English.
Barry - moderator.
On AC i've only rounded angleOn AC i've only rounded anglein illustrtaor i've "pointed" anglein illustrtaor i've "pointed" angle
27 Replies 27
Ahmed_K
Mentor
Helle, there is no solution fot this, it's a defaut system setting
Archicad 27
Windows 11 professional
cuba
You can use very thin walls with zero line thickness and solid fill to draw sharp corners...
Apple M1 Max 32 GB
Latest AC
This is a very old wish that has been asked by many users in the past.
pcrossington
Why has Archicad not fixed this? Is there a particular reason it can't be done?
Eduardo Rolon
In my case I don't consider this a bug but you can make a wish so that they add a preference to choose that the corners have options like Illustrator.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Martin Jules
Mentor
I have the same issue with the ArchiCAD dimension tool which can't give me something like this:
Martin Luther Jules
AC 10-29 (Full)
Asus | 64 GB RAM | Windows 11
If you were drawing with a pen or a pencil, you wouldn't have square ends.
I don't see this as a problem.
I don't think you would ever notice when you print the plans.
It is only noticeable on screen because you can zoom in so much.
Martin Jules
Mentor
It's a problem to meet the standards of the company. Every CD must have the same look when printing them. They are very strict on that.
Martin Luther Jules
AC 10-29 (Full)
Well, if the company can tell the difference between a round or square end on a dimension marker printed at 1:100 scale (actually the scale does not matter as the markers will be the same size no mater what scale), they have way better eyes than me and way too much time on their hands to be that picky.
