true line weight archicad, angle shape
Averrell
Salut!!
premièrement je voudrais m'excuser pour mon anglais je suis français 😅
dans un deuxième temps, j'aimerais savoir s'il existe un moyen d'avoir un "angle pointu" comme Illustrator lorsque j'utilise une épaisseur de ligne réelle? j'ajoute une capture pour expliquer ce que je veux:
Translation...
Hi!!
first I would like to apologize for my english I am french 😅
Secondly, I would like to know if there is a way to have a "sharp angle" like Illustrator when I use real lineweight? I add a capture to explain what I want:
Please post in English only to this forum.
Normally this post would be removed, but as it has been replied to already I have translated it.
Please use Google Translate (or similar) so you can post in English.
Barry - moderator.
On AC i've only rounded angleOn AC i've only rounded anglein illustrtaor i've "pointed" anglein illustrtaor i've "pointed" angle
22 REPLIES 22
I am not sure they will take it into account, as usual. It will simply benefit other companies which will read our wishes and put them into effect.
Martin Luther Jules
AC 10-28 (Full)
Asus | 64 GB RAM | Windows 11
You're right @thesleepofreason! The pdf outputs from ArchiCAD are so different from those of other software in terms of cleanliness that I often wonder what is not working with ArchiCAD? I think major upgrades are necessary to comply with the generally accepted presentation norms that are into force around the globe. For information, the ArcGIS is available into the Vectorworks interface. It's about a great tool and update for urban designers.
Martin Luther Jules
AC 10-28 (Full)
By not listening to us, ArchiCAD is becoming obsolete on many points.
Martin Luther Jules
AC 10-28 (Full)
