Averrell
true line weight archicad, angle shape
Salut!!
premièrement je voudrais m'excuser pour mon anglais je suis français 😅
dans un deuxième temps, j'aimerais savoir s'il existe un moyen d'avoir un "angle pointu" comme Illustrator lorsque j'utilise une épaisseur de ligne réelle? j'ajoute une capture pour expliquer ce que je veux:
Translation...
Hi!!
first I would like to apologize for my english I am french 😅
Secondly, I would like to know if there is a way to have a "sharp angle" like Illustrator when I use real lineweight? I add a capture to explain what I want:
Please post in English only to this forum.
Normally this post would be removed, but as it has been replied to already I have translated it.
Please use Google Translate (or similar) so you can post in English.
Barry - moderator.
On AC i've only rounded angleOn AC i've only rounded anglein illustrtaor i've "pointed" anglein illustrtaor i've "pointed" angle
27 Replies 27
Martin Jules
Mentor
I am not sure they will take it into account, as usual. It will simply benefit other companies which will read our wishes and put them into effect.
Martin Luther Jules
AC 10-29 (Full)
Asus | 64 GB RAM | Windows 11
Martin Jules
Mentor
You're right @hevi! The pdf outputs from ArchiCAD are so different from those of other software in terms of cleanliness that I often wonder what is not working with ArchiCAD? I think major upgrades are necessary to comply with the generally accepted presentation norms that are into force around the globe. For information, the ArcGIS is available into the Vectorworks interface. It's about a great tool and update for urban designers.
Martin Luther Jules
AC 10-29 (Full)
Martin Jules
Mentor
By not listening to us, ArchiCAD is becoming obsolete on many points.
Martin Luther Jules
AC 10-29 (Full)
pcrossington
I feel the same way. They are not listening, which is apparent by the response form the moderator on this thread, who is dismissing our needs by saying "i don't see it as a problem" Well, I do see it as a problem as I can't get my drawings to look as clean or as sharp as with other programs. Very frustrating.
What ever we say as moderators is our own personal opinion and nothing to do with Graphisoft.
As forum moderators we are permitted to move posts to the correct forum and delete offending/spam posts.
We have no more say in what Graphisoft does than you do.
Feel free to express your opinion and suggest what you think might help.
Go to the wishlist and vote if you want to support any of those wishes.
Post some examples of the problems you are having and someone may have a solution for you.
Guru
I see that this is another case of wishes getting archived to the void...
If they were in the old wishlist, maybe they did not make the top 100 or so that got moved over to this new wishlist.
However there was a new wish created just a few weeks ago.
https://community.graphisoft.com/t5/Wishlist/Pen-width-offset-and-corner-display/idi-p/665343
Gabor Szelei
It's probably more important for them to spruce up the kitchen cabinet door handle 🙂
Versions 6.5 to 28, AMD Ryzen 9 3900x, 32GB ram, GeForce RTX 2070 super, Windows 10
