urban designing problem with archicad. Need help.
Hei every one. Iam working with landsacpe and urban designing. And i decided to use archicad. It started very good and flexible, but after i draw the landscape and tried to put roads so the problems just show up. the problem is that when i intersection the road with landscape in solid element operation tool, so it tooks hour to finish the job. I am really confused to how work faster. I do not really want start drawing with hands
I hope i could explain well. the urban area is 1640 m * 800 m . kinda huge area.
I would really be grateful for any help.
Thank you.
And sorry for my english
4 REPLIES 4
alemanda
Try to avoid boolean operations ... the magic wand should be helpful ...
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
Is it possible to show the tool with a pic ? The tool is really new for me.
Thank you alot for helping.
Mats_Knutsson
Mentor
Thank you.
Hej,
Call Graphisoft Norway and they'll help you. The area is not that big unless you have too many mesh nodes which could be your problem. Norway is however not flat like a pancake...šŸ˜‰
Hilsen fra Sverige
AC 25 SWE Full
