variable wall thickness
Hello.
Is it possible to draw a wall in archicad with a variable wall thickness? In the picture I show the wall and with a line its desired shape.
Thank you,
4 REPLIES 4
Hello.
Thank you,
Eduardo Rolon
You can use the Trapezoid option for walls.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thank you. That was it.
Sure.
Try the trapezoid or polygonal wall geometry methods.
