2024-11-19
		04:18 PM
		2024-11-27
		08:46 PM
when trimming a wall to a basic composite roof it looks like the trimming surface is to the top of the roof rather than underneath so the structure of the wall is visible. How can i change this to hide the wall?
Solved! Go to Solution.
2024-11-20 09:52 AM
If your roof is not a composite, set it to use a building material that is stronger than any used in the wall.
If it is a composite, edit the composite so the building materials used are stronger or choose a different composite that already users stronger building materials.
Basic principle is stronger material cut weaker ones.
2024-11-19 06:27 PM
Hi @EGM66,
It’s a material priority issue so try to use SEO it will work for you.
2024-11-20 01:57 AM
Or make the building materials in the roof stronger than those in the wall.
2024-11-20 09:24 AM
Thanks, that worked for me
2024-11-20 09:25 AM
hi Barry how would i achieve that?
2024-11-20 09:45 AM
Options => Element Attributes => Building Materials => [BM in question] => Intersection Priority
*I think this path changed in the recent versions of AC.
**The may cause undesirable changes to other intersections
Ling.
2024-11-20 09:52 AM
