2024-11-19 04:18 PM - last edited on 2024-11-27 08:46 PM by Laszlo Nagy
when trimming a wall to a basic composite roof it looks like the trimming surface is to the top of the roof rather than underneath so the structure of the wall is visible. How can i change this to hide the wall?
Solved! Go to Solution.
2024-11-20 09:52 AM
If your roof is not a composite, set it to use a building material that is stronger than any used in the wall.
If it is a composite, edit the composite so the building materials used are stronger or choose a different composite that already users stronger building materials.
Basic principle is stronger material cut weaker ones.
2024-11-19 06:27 PM
Hi @EGM66,
It’s a material priority issue so try to use SEO it will work for you.
2024-11-20 01:57 AM
Or make the building materials in the roof stronger than those in the wall.
2024-11-20 09:24 AM
Thanks, that worked for me
2024-11-20 09:25 AM
hi Barry how would i achieve that?
2024-11-20 09:45 AM
Options => Element Attributes => Building Materials => [BM in question] => Intersection Priority
*I think this path changed in the recent versions of AC.
**The may cause undesirable changes to other intersections
Ling.
AC22-28 AUS 3001 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2024-11-20 09:52 AM
