dhnguyen
wall fill settings
Both of these walls have the same height. I want the striped wall to stop its fill when it hits the solid filled wall, which settings do I click on to change that? Thank you.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
The solid filled wall needs to have a building material with a higher strength value than the one used for the striped wall.
Lingwisyer
Guru
Intersection Priorities of materials can be seen on the right of the materials drop down when you cursor over one.
Created/Modified @
Options => Element Attributes => Building Materials => Intersection Priority
Ling.
