Gus wrote:
I think it might have been the fact that I had an existing wall that was the same as the modified wall. Since I am doing an addition I have existing plans then another set of plans over that showing the modifications.
I'm having trouble figuring out a good way to have an "existing" model in the same file as the "modified" model without weird overlap things happening. I am wondering what other people do in similar situations because it's important to have exiting plans and not to mess with them. It's also good to have a demo plan which has the same "duplicate walls" effect it seems.
Ah, so Hmooslechner was correct in his guess.
Well, AC now has a renovation feature that allows elements to be tagged as existing, demo, new and to generate uniquely displayed drawings for each type of plan.
Since you are still on 14, the only method there is with multiple layers - but you need to make sure that hidden elements do not interact with visible ones. So, for your existing plan, where new elements are hidden, or your proposed plan where demo elements are hidden, those elements must have different intersection priorities in the corresponding layer combinations so that they do not interact with the visible elements. There is a lot of old discussion about ways of managing renovation / remodeling work with screenshots if you search the forum.
Besides reducing the number of layers for a renovation project by about 1/3, the new renovation feature provides custom model view options - changing fills, pens, etc - for demo elements in a demo plan, vs how they appear in an existing plan, etc. Along with Morph and many new features, worth considering an upgrade to 16, or some time time year, to 17.
AC 28 USA and earlier • macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
