2008-05-19
11:04 PM
2023-05-23
03:10 PM
Rubia Torres
2008-05-19 11:46 PM
2008-05-20 12:13 AM
2008-05-20 12:25 AM
2008-05-20 12:32 AM
2008-05-20 02:08 AM
2008-05-20 03:15 PM
2008-05-20 03:53 PM
Maiya wrote:Use Solid Element Operations. The you can skip the convert to roof step.
So I could trim walls then to the level of roof.
2008-05-20 05:19 PM
2008-05-20 05:24 PM
Maiya wrote:I guess your mesh is either not solid (just a wavy surface) or has a flat bottom/underside).
I was able to convert mash into roof, but I couldn't even trim walls even if I wanted, cause it isn't working ok with that kind of roof, cause it only trims walls that can stay straight on the top.
How can I use solid element operation in that way? I read it in archicad help and try it but nothing happens. Guess I don't know how to set it up right.
