what is this problem ????
why this problem ??? how i can to remove it ???
6 REPLIES 6
Dwight
Do not write the report.
Dwight Atkinson
Thank you
Ali,
I will ask again: give your questions a meaningful subject that has to do with what the problem is. Your prior posts of "Question", "QUESTION???" and now this "what is this problem ????" are not acceptable.
Specific subjects help people help you ... and help other people in the future who are seaching for answers.
Thanks,
Karl (wearing moderator hat)
Welcome
I am in fact was intended to address how to resolve this problem
I do not know what will be the title in fact is a problem I do not know how to solve it, I am a novice in this program only for me two months I am working on
Ali,
1) Make an effort. For example, describe what were you doing when the problem appears.
2) Before asking try to repeat the problem. That is the minimum first step in trying to fix it yourself.
3) Then play with settings of whatever you were using at the time.
4) After you have "done your homework", then ask away.
Snap
PS Please post you questions on one problem in one (not multiple) threads.
Thank you for this clarification
But the problems come behind each other
I understood the idea I will try next time I pass that what I said
