SOLVED!
why this slab cuts my wall? :arrow: :arrow:
aryastark
infuriating problem...
this wall shouldn't be cut through slab but it is.
when i hide slab, you can see wall real high is higher than how it seems.
why could it be? i want to see all real wall.
(not worked)
(hided slab)
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
1 ACCEPTED SOLUTION
Solution
Eduardo Rolon
• First recommendation is that you should not use a Slab for a terrain. Reason is that it uses Building materials and it will cause the problem that you are seeing. Also eventually it will slow everything to a crawl because it needs to evaluate every single Building Material Priority, So terrain even if it is flat it should use a Mesh.
• If you still want to use a Slab for this then you will need to place this slab in a dedicated layer with a different intersection number, 0 or 500 and then it will not intersect.
HTH
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
1 REPLY 1
Solution
Eduardo Rolon
HTH
AC29 US/INT -> AC08
another Moderator
