window issues
I am getting loads of "polygon is degenerated" error messages when I try to view my model in section or elevation...I have been tweaking the parameters to try to get the windows to look like I want, so I must have tweaked Something, but I can't figure out what, really, is causing these errors. Is there any way to discover their source?
1 REPLY 1
Djordje
Set your Report to Detailed in Options/Preferences, generate the view that activates the error messages, open the Report window and read it through; it will tell you which library part generated the error messages and you can see what the problem is.
In general: if the Preview of the library part complains, there is something wrong with the parameters, and you are forcing them to misbehave.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
