window marker fill opaque does not work!!
Okay, so i have the window marker setting to an opaque fill and it shows properly in view map floor plan view.
however when it is transferred to a layout it no longer is opaque. I need to make it opaque for printing (the layout view is updated). Anyway I am stumped.
4 REPLIES 4
second screenshot
NCornia
Graphisoft Alumni
Graphisoft Alumni
That is a mystery and an annoying one at that.
I am just shooting in the dark (as I cannot see how this occurred) but what if you change the display order of either the windows or roof.
Select windows or roof and select Edit>Display Order> Send Forward (or Send Backward.
Maybe moving them up and then down again may do something? That would be something I would try. Good luck.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
hey that worked. I had tried earlier to change the display order of the window elements but it is not allowed.
The roof however can be sent backward and voila! problem solved! thx.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Awesome! Well it was just an educated guess. Glad that it worked for you.
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
