2003-11-30
12:31 AM
2023-05-26
03:30 PM
Rubia Torres
2003-12-01 03:31 PM
Djordje wrote:Just checked in 8.1 INT R1.Dr wrote:I will have to check, but I seem to remember that whatever is set in the 3D window when you define the elevation QuickView gets remembered. I usually keep the transparency on in 3D, but make a point of switching it off for the elevations (confuses most people).
As far as I am concerned, this is a major problem. You can not save elevation view sets with the option of window transparancy on or off. The elevation views are at the mercy of the 3d window. This is not right and in my mind requires an immediate fix.
Will check and report back.
