window with slanted sill
hi
how to create a window with slanted sill?
would appreciate an answer
ana
Hi Ania,
In which direction would you like the cill to slant? I'm guessing you mean you want lower part of the window to follow an angle (perhaps over a roof) leaving you with a non square window.
Two ways to model this - either build a custom window using slabs/walls, (see the section on 'Graphic Creation of Custom Objects' in the reference guide for instructions.)
Or use the freeform window mentioned on this thread - http://archicad-talk.graphisoft.com/viewtopic.php?p=139836. This is the easiest option.
Also if you wanted a particularly complex cill, use a separate complex profile assigned to a sloping beam, and place in front of the window manually.
Hope that helps.
Thanks Peter
your window works swell.
