windows within niches
Rakela Raul
how do i put a window inside a niche?? where the thinner wall is...when you put a wdw in the thinner wall, ac reads the thicker wall.....share experience please, thx
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
8 REPLIES 8
Are you saying that you have 1 thicker and 1 thinner wall lined up next to each other or do you mean that the placed niche has made your originally thick wall thinner att that particular spot?
In any way, I believe that in the International library you need to pick the niche that resides in the Windows/Openings folder ("W Niche.gsm"). The niche inside Building Element's folder does not operate the same way.
Rakela Raul
your second statement susanne..thx for responding........
...........i will use the opening gsm, then draw a thinner wall inside the opening
and then put wdw in that thinner wall...then in plotmaker i will delete extra lines to make it look drawn properly.....another one of those so calld 'work arounds' seems to be...thx again and enjoy the weather
Erika Epstein
It used to be when one unchecked
"frame depth = wall depth"
that you could then set the frame depth independantly.
It would be good to have that back.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Rakela Raul
erika thx,
do u remember ac version??
Rakela Raul
i'm getting it back to you:
under "metal windows 9" "awning w awnU"
thx
...........i will use the opening gsm, then draw a thinner wall inside the opening and then put wdw in that thinner wall...
you don't need to put a thinner wall to place a window inside the placed W Niche.gsm. Just "throw" the niche in and then place the window inside the niche. That works just fine.
Erika Epstein
I realize my photo post didn't get posted,
Perhaps this will help.
AC8.1 lib
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Rakela Raul
thank u so much susanne and erika..it took me only till 3am to feel good about it....i played with 'frame depth' and i used the metal wdw in ac9 lib and a little bit of guess work..and it looks v decent now.....thx again
