wire netting
Hello
How can I build in 3D a rounded structure in wire netting?
(how can I do the wire netting?)
Thanks for your help!
Charlotte
6 REPLIES 6
Dwight
what version of ArchiCAD?
Dwight Atkinson
I have Archicad 6.5 ! šŸ˜‰ (yeah I know I should have a better version...)
So how can I do?
Thanks for your help.
PS: I'm talking about wire mesh... How can I do a 3D structure in this?
I usually make it in MAX or AutoCAD. Every app has its limitations!
Sorry!
Dwight
It is not practical to make a mesh in 3D. Too many polygons.
If you are doing it with a rendering, then a masked texture will work.
apply both bump and transparency.
Dwight Atkinson
thanks a lot! yes I'll use it...
