working 3d ?the rotating,facede,axo window is gone!! please
i am a new user of archicad.
i start a 3d view and i don't know why the automaticaly afferent window that let you to rotate the 3d model is gone.
how can i make it to appear again????
i forgot even the name of it!
maybe from thos question you realise that i am really a beginner.
but i want to learn...and the problem is that i must do it only with your help.
thanks
4 REPLIES 4
Windaow/Palette Display/Show Main Palettes Only....do this in 3d view...
thanks
i did it!
i can see it again!
Something you might like to try is to hold down the shift button and use the scroll wheel on your mouse whilst in 3D mode. This will allow you to rotate the model without having to select the rotate button tool. When you stop scrolling and release the Shift key it returns to a static view of the model and the model can be edited again.
Stress Co_
If I ever knew that one...... I forgot it... thanks for the tip.
Marc
Marc Corney, Architect
Red Canoe Architecture, P. A.
