worksheet independent
Llian
worksheet independent ...why use this for xref file? what does it do?
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
7 REPLIES 7
David Larrew
Independent Worksheets are good for storing 2D reference items (like .DWGs and .PDFs) that you are not going to use for documentation (Marker references). Worksheets are just another "workspace" for 2D information.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Llian
thanks. i created a new worksheet , xref dwg site plan, but it's now showing up in my plan??
Lilian Seow
David Larrew
You have your Trace Reference "On" and set to your Worksheet.
AC 5.1-25 USA
Llian
sorry i meant 'NOT' showing on my model plan. i have read the manual over and over and still don't get it!
what i am trying to do or understand from the manual is you can have the xref on the independent worksheet next to the model plan so i can refer to as i work on the model plan.
the trace icon is 'on'. i'm in model plan. i select the independent worksheet [where my xref dwg plan] on my navigational panel and then what ?
this may sound 'stupid' on my part but i just need some more simplification in doing just that step.
sorry i am frustrated !
Lilian Seow
The easiest way to set any viewpoint/view/layout as Trace/Reference is to right click it in the navigator and chose "Show as Trace Reference". The Trace/Reference palette also retains the last 5 reference views in the popup list.
And, after you have shown some as Trace Reference, make sure to zoom to show all.
Sometimes the Reference appear far from the building and you have to use the Drag Reference command to place it in its correct position.
Did you check the visibilities sliders?
It happened to me.
Just a guess.
