zone fills in 3d
Is it possible to use the colors used in zone fills when viewing in the 3d window?
TIA
Adri
5 REPLIES 5
Erika Epstein
Yes.
Under View,
Elements in 3D view,
Filter elements in 3D view
Check the Zones box
Typically zones are not checked as they would interfere with the regular renderings and section elevations.
You can save separate 3d views one where zones will show in color and one not (the norm) to more easily toggle between these settings.
Interesting to note that in AC10 there no longer seems to be an option for building to show as wireframe with only the zones as 3D color, or am I missing a new place to set this?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I thought this was the only way to view Zones in 3D with AC9?
I believe that the Zone material will show in the 3D window, but not the colored fill (unless you create a material that matches the fill and assign it to the appropriate Zones) -- yes? no?
Erika Epstein
Yes. More a note of improvement in 10. The effect of wireframe building with colored zones can be easily recreated by setting the appropriate building element layers to wireframe.
Correct. The fill is for floor plan display, the model material for 3D.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Djordje
AFAIK there is an out-of-the-box layer combo that does just that? Maybe not in the US version, though ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Erika Epstein
Thanks Djordje,
I'll take a look.
Are you sure you meant layer combination? I'm not finding one; do you remember which one?
Or were you thinking or the check box for use fill of surface material int the Zone Selection Settings box on the floor plan tab?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
