yesterday
- last edited
2 hours ago
Noemi Balogh
yesterday
you have to use the surface schedule in order to know the exact area of a surface.
If you try with the element schedule you can get the value "surface area on ouside face" or "inside face" but this value does not take into account penetrations due to PBM and SEOs ...
5 hours ago
I have already tried with an abacus created for surfaces but I get wrong values, for example for a simple room I get different values (including or not the thickness of the wall in the intersection areas) depending on the fields and I don't understand what I have to do to get the right result (I attach an image). I apologize again if my request seems triviale, and thank you
5 hours ago
No need to be driven crazy just yet 😆. @JaredBanks who is an Archimaster of residential design shows an accurate method using zones & schedules to extract accurate wall surface quantities.
I like his method very much and it is simple and easy to follow. He tests it, to show us how when a door is removed from the model and you update the schedule the quantity adjusts correctly.
Please see his method on his excellent tutorial video below.
https://www.youtube.com/watch?v=tWyUnDTBtG4
4 hours ago
Thank you very much, but in this video I seem to understand that it shows how to calculate and find the surface areas of the walls of the internal rooms, I would need a solution/method to find the area of the external surfaces
3 hours ago - last edited 2 hours ago
Yes he has zones set up for external areas from what I saw on the video. You can private message him to ask for more information on how he extracts that external painting area from the model.
This older post also may help with calculating external wall area ?
