2 weeks ago
- last edited
2 weeks ago
Noemi Balogh
2 weeks ago - last edited Sunday
you have to use the surface schedule in order to know the exact area of a surface.
If you try with the element schedule you can get the value "surface area on ouside face" or "inside face" but this value does not take into account penetrations due to PBM and SEOs ...
Here's a sketch. 4 walls; 2m long, 2m high and one opening 1 m x 1 m; wall thickness 20cm. Expected yellow surface 4x4 - 1 + 4x1x0,20 = 15.80
Then you can setup a schedule of surface (not of elements; in archicad there are 3 types of schedules) and you get the correct surface area, filtering by surface name
I sent a private message to you. I'm Italian too. Check your inbox in the forum platform (top-right corner).
2 weeks ago
I have already tried with an abacus created for surfaces but I get wrong values, for example for a simple room I get different values (including or not the thickness of the wall in the intersection areas) depending on the fields and I don't understand what I have to do to get the right result (I attach an image). I apologize again if my request seems triviale, and thank you
2 weeks ago
No need to be driven crazy just yet 😆. @JaredBanks who is an Archimaster of residential design shows an accurate method using zones & schedules to extract accurate wall surface quantities.
I like his method very much and it is simple and easy to follow. He tests it, to show us how when a door is removed from the model and you update the schedule the quantity adjusts correctly.
Please see his method on his excellent tutorial video below.
https://www.youtube.com/watch?v=tWyUnDTBtG4
2 weeks ago
Thank you very much, but in this video I seem to understand that it shows how to calculate and find the surface areas of the walls of the internal rooms, I would need a solution/method to find the area of the external surfaces
2 weeks ago - last edited 2 weeks ago
Yes he has zones set up for external areas from what I saw on the video. You can private message him to ask for more information on how he extracts that external painting area from the model.
This older post also may help with calculating external wall area ?
2 weeks ago
This other video I did should cover exactly what you want: wall surface area.
https://youtu.be/_OcTE242CfU?si=ZHqVmKHQZt7k26KL
In the video I do tests with fills and different scheduled fields to confirm I have the right information.
2 weeks ago
We developed an Archicad add-on for intuitive area takeoffs. Search “AvroForm” on Google for details.
a week ago
Hi @Jihoon, Do you have a direct link for this add-on ? I have searched it with that spelling and I can’t seem to find it.
a week ago
Thanks for the reply.
I've already seen this video, but I need to take a closer look. In my case, if I use the same fields and verify their accuracy, even just to test on a simple shape, I get incorrect results for one reason or another (the surface area totals take into account the wall thicknesses on some walls and not others; if the wall is recessed, the entire calculation is calculated, not just the portion remaining outside, etc.). I'll try to take a closer look anyway.
