We value your input!
Parametric design
About Rhino & Grasshopper and PARAM-O.
AC21 Live connection install error
Bruce
When trying to install the Grasshopper-Archicad live connection for AC21, I get a message telling me it's already installed...but it isn't (see image).
I have it installed for AC20, but nothing for AC21. Does anyone know what the story is here?
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Robert,
If you still have that issue, this might be what you are looking for:
https://helpcenter.graphisoft.com/?p=75721
If not, then please before exiting the installer, open the 'Window>Install Log' menu, save the install log with the save button, and send it to me in a private message, so that I can take a look at what process might fail.
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
7 REPLIES 7
abdelaziz
I too have this problem even though I have uninstall AC 20
AMD Ryzen 5950x
AMD RX 6750xt
AC27
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hey guys,
This is a known limitation of the installer: it sees the ARCHICAD 20 version and clashes with it. You can find out more about it in this ReadMe.
We are working on eliminating this problem for future versions.
Regards,
GRAPHISOFT
Bobby_ja_tt
Hello Everyone,
I am currently trying to install GH AC21 Live Connections and I am getting the following error.
I have deleted the gh ac connection for 20 but still no luck.
Can anyone offer some advice as to how to solve this issue?
thanks in advance.
Robert Thompson
Ackee Workshop
_________________
Archicad 9-21 FULL
Rhino 5 (mac)
MacBook Pro
2.8 GHz Intel Core i7
16 GB 1600 MHz DDR3
__________________
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Robert,
Thanks,
GRAPHISOFT
Bobby_ja_tt
Hi Daniel
Ive managed to get it to work.
Thanks so much for your help.
Robert Thompson
Ackee Workshop
_________________
Archicad 9-21 FULL
Rhino 5 (mac)
MacBook Pro
16 GB 1600 MHz DDR3
__________________
Hello. AC Live Connection breaks down my grasshopper - just after openning grasshopper Rhino crashes. If I remove the gha file from libraries it works, so I'm sure it's this plugin.
Can You Help?
____
I work on windows, have Archicad 21 and Rhino 5
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Can You Help?
____
I think you might have run into the problem of different Grasshopper Add-ons clashing. Please see this thread for the solution:
https://archicad-talk.graphisoft.com/viewtopic.php?t=59542
Regards,
GRAPHISOFT
