martyna_
Archicad - Grasshopper selecting objects
Hi, when I'm using parameter tools, for example windows
is there a way to automatically select all the windows in the project instead of having to click on all of them?
pleasse help its so annoying having to select them like that
1 Solution
I just tried it and it works: select all the Windows in Archicad, then invoke the "Set multiple Windows in Archicad" command in Grasshopper. All selected Windows will be set and stored in the Grasshopper component. So, you do not have to select them one by one.
Go to post
4 Replies 4
What happens if you select all Windows in Archicad first, and then invoke the "Set multiple Windows in Archicad" command in Grasshopper?
martyna_
Thank you so much!!! it will make my work so much easier
rubymoon
hi this does not work for all objects, some of the objects can be selected by multiple but some of it needs to pick one by one
