AFAIK gradients won't import.
The reason would be import as an image, is not to mess up your attributes, as each Rhino colour is going to be imported as a separate "Surface" - so if you bake a coloured mesh from the analysis result, you will be fine, you will have your analysis mesh in ARCHICAD. If you are doing a fine analysis, it is going to be dozens, which I would rather not pollute my file with. The import won't change your linetypes to the respected colours, so you either create
- a 3D document to clean up from the boundary lines (both 2D and 3D analysis)
- openGL view (both 2D and 3D)
- import the result as an image, scale it to fit your floor plans (2D only).
The benefits of creating a 3D document is the vector quality over a raster image, which could be easily overcome via saving a larger image. To achieve that, you can use the "ViewCaptureToFile" instead of "ScreenCaptureToFile" command in Rhino. You can set up a decent resolution and no one will notice a drop in quality in your drawings. To see the results in BIMx/openGL, just create a Surface with your image.
odv.hu | actively using: AC26-28 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
