2021-03-25
		12:44 PM
		2023-05-25
		09:07 AM
			Noemi Balogh
Gordana Radonić
Community Manager
2021-08-25 11:39 AM
Podolsky wrote:I wholeheartedly agree with Podolsky apart form one thing: You will be able to grasp some of the concepts (and limitations) behind param-o much faster if you know at least basics of gdl coding.
My opinion that PARAM-O is quite limited in term of modelling capabilities. PARAM-O is generating GDL script, that later ArchiCAD is reading.
Knowing GDL well - it's possible to achieve much faster better results. But only if you know GDL well.
But it's good tool to start learning GDL.
2021-09-03 04:42 PM
Hello Everyone, I have started to explore Param-O and found it interesting for making needful customization easily as per project needs. Just posted few video clips on my YouTube Channel. If anyone is interested can visit there and explore the given examples. It would be great if you can send me your feedback especially if I can improve somewhere on the programing point. Regards. https://youtube.com/playlist?list=PLw82vkgAgA1UI7WAsmIWjIEOSrg1qbR1A
2021-09-04 11:53 AM
Hi, I hope you are looking for something like this. Download and check this video clip.
https://drive.google.com/file/d/1TqtknHP1wRnTiDe_GB9zUjiazXQS2Juq/view?usp=sharing
2022-04-06 08:24 PM
I think Parma-O is a good answer to Revit's family editor. Someone has said that Param-O's features resembles Archicad 2. Param-O does a sufficient job making parametric 3D-objects. For the Norwegian audience I have made a quite visual booklet on GDL and Param-O. A small part of the booklet is attached here. Graphisoft: I really hope for more tools inside Param-O. And for more instruction videos.
2022-11-07 09:31 AM
HI,
I was working on some objects but i stucked when i need to create custom 3D text. I will be obliged if someone could help on that.
Thanks
2022-11-07 10:59 AM
I guess you have posted on wrong forum. Still the one possible answer for your 3D text requirement is from "Object" tool "3D Text"
2022-11-07 11:41 AM
Thanks for reply Rajesh!
My question is that- Can we create parametric 3D text in Param O? Yes it's already available in objects but Is it possible to create 3D text (like 3D Room Tagging) in Param O as like Dynamo?
