We value your input!
Parametric design
About Rhino & Grasshopper and PARAM-O.
Select archicad object
Hi All,
I have one question about archicad live connection with grasshopper
how I can select stair in archicad convert into Rhino via grasshopper?
I select grasshopper component but I can not select stair object in Archicad?
Thanks
3 REPLIES 3
I am assuming this is AC21 or 22.
ARCHICAD has element types, such as Wall, Column, Door, Window, Stair, Railing, Object, etc.
So an Object is an element type that is created with the Object Tool.
A Stair is an element type that is created with the Stair Tool.
When Grasshopper wants you to set an Object, it wants you to set an element created with the Object tool.
Maybe the confusion comes from the fact that in some other applications everything you create is called an "Object", while in ARCHICAD everything you create is called an "element".
So in ARCHICAD, an Object is a specific type of element.
In ARCHICAD you do not have a "Stair" object. You have "Stair" elements and "Object" elements. It is a different nomenclature.
I am sorry, now I remember what the situation is.
Stairs and Railing are not yet supported by the Grasshopper- ARCHICAD Connection because they were both recently added in AC21, and are both very complex so it takes more time to add support for them in the Add-On.
That is why yo do not see any Stair/Railing and Deconstruct Stair/Railing Nodes in the ARCHICAD Add-On.
Unfortunately, I have no info on when it is coming...
