lmcardoso
extract parameters from object to ifc
hi all,
any way to extract paramters from param o objects so they can be read in ifc readers like bim collab/solibri?
thanks in advance
Operating system used: Windows 10
ArchiCAD 23/25/27 with Win 10
2 Replies 2
Kamelite
Add your properties the toe the Param-O the usual way, In the IFC-exporter, you map them out, so that they will be exported...
.Kamelite
Windows 10, Archicad 27,28 and 29
Kamelite
Made a test, a simple cube, in Param-o, gave it a property and a P_set, then exported it to IFC. Something like that?
