2018-03-08
11:45 PM
2023-05-11
11:09 AM
Noemi Balogh
2018-08-24 07:09 AM
2018-09-14 04:11 PM
2018-09-15 04:18 PM
2018-09-16 10:40 AM
2018-09-17 08:53 AM
iulmann wrote:Hi,
Hey Guys,
I have a similar problem. I could install both of the components to AC and GH, but after I run the connection in AC21 (works properly), in Grasshopper when the windows pops up the 'Connect' button is not active, therefore I can't make the connection between the 2 programs.
Is there a solution of this?
Thank you so much!
2018-09-17 11:07 AM
2018-09-17 05:40 PM
2020-10-30 11:01 AM
2020-11-02 01:04 PM
Ryan wrote:Dear Ryan,
Opened terminal and:
sudo pkgutil --forget "com.graphisoft.ArchiCAD.Goodies.GHACLiveInstaller
Could you explain this bit some more please? Is that a command line entered in the Rhino command line? I have a similar problem where the Live connection doesn't work even though GH is running
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
